ProjectRadianRobosub
Hello, we are a second year robosub team trying to create a small underwater robotic submarine. I realize this isn't really the place for submarines, but we found the multi-rotor community extremely helpful last year, and were hoping for some help with an issue we're having.
We saw a team successfully run brushless motors underwater last year, so we decided to try it. We bought this motor for testing:
amazon.com/dp/B075ZSDR2T/ref=sspa_dk_detail_0?psc=1
It was cheap so we figured it'd be a good disposable motor. It did run well underwater, but was drawing over 20 amps(our multimeter only measured up to 20 amps). On amazon the max current listed is 10 amps(I think) but the only issue I've read about with over amp-ing is overheating, something that won't happen while it's submerged in water. If I'm wrong, please correct me, that's why I'm posting. An issue that arises is that once we have 6 motors running, each drawing 20+ amps, I'm not sure we can fit a suitable battery in the small hull of the sub. I suppose here are our main questions:
- Are there any issues besides overheating with running motors far above their max listed amperage?
- How can we choose motors to reduce current draw in these conditions?
- I assume we should look for a low KV, since the motors will be running slow anyways. Does that sound right?
Thanks.
Thanks.
