o matter what colorFirst thing you need to do is make sure you have the right transmitter, there are 2 versions I know of, Blue light and green light. There is no different procedure to follow, the binding process is the same as if you were binding the orginal transmitter.
Thank you mr JacksonTurn on quad. With throttle in DOWN position, turn on radio. Light will be flashing, move throttle UP to top then back DOWN. Light will be steady.
