Hello I have a x8g quad copter that i have new batteries for that are fully charged. test at 8.5 volts. controller links to copter but flashes the light like the battery has low power. What can i do?
Do you mean the drone lights are flashing?
While lights are flashing, move the LEFT stick UP and then DOWN once. Will the lights turn stable?
If that does not stop lights flashing, are you able to launch the drone anyway?
If yes, you can still launch the drone, then the next question is ..... will the battery allow reasonable flight time or you get "low battery" warning very quickly?
RE : i have new batteries for that
Did you mean new batteries for the drone?
If yes, I can't think of a reason why no flight except that you drone has been damaged.
Did you have a few crashes before you have this problem?
