you are correct I checked the power connectors and those 2 are dead I switched the connectors for my FPV and battery meter and all is good. I plan on removing the harness and finding the break. I have another question...whenever I take off, the drone wants to tip over when I throttle up. is that something I'm doing wrong or is my idle speed too low? Ive destroyed a set of carbon fiber props from crashes during take off and I would like to figure out why. thanks mate you are a lifesaver
Hi mate it is really important that the following is right , all motors start and stop at the same time, the quad is balanced 100%, the fcb and sensors are calibrated with quad 100% level ,all sensors should came back OK when tested
