C.B. Russell
Active Member
Got it together while waiting on your response and hooked up to betaflight configurator. I'll see how it works and checks. Had to print out custom cam and board mount. We'll see.
Eh? You mean when you hook up battery got some pics to show your setup progress.TBS Unify EVO no power?
VTX is jumped to battery.Ah you powering the vtx off the FC? If so using battery power to the FC (USB to FC will only give it 5V)? Would have to check if FC puts out at least 7V on that line too it may be 5V out. Usually there is a 12V pad for led strip power or other things that need more than 5V will see if I can find power output from FC but if trying with just USB (5V) wouldn't expect the vtx to power up necessarily.
Would try to check voltage at vtx input with a voltmeter/multimeter see if can confirm the voltage in is in range.VTX is jumped to battery.
This is actually pretty normal for any vtx they get uncomfortably hot when just sitting on the ground especially.. This is another reason pit mode exists so power isn't just being bled off and signal unused but if flying the whole time then the heat is just biproduct of amplification of the signal (this is why you don't want to run a vtx without an antenna attached if no antenna "load" for the amplified signal to transmit out then more heat builds up)Hey guys, TBS Unify EVO 5.8GHz Video Transmitter is getting really hot, how can i change or fix this, it is jumped to battery and I'm looking for a 12v connection on FC.
