Everso
Hi all
I recently bought a 250 quadcopter and a load of bits. It was however a mess of sticky pads and cable ties. It also had troubles flying (went up a bit then came back down). So I decided to strip it all down and start from scratch. I thought I had good enough pictures to get it back together again but it turns out not so much... Much googling has not helped me out so I was hoping some kind soul here would take pity on me and offer some advice.
What I have (had) was a 3 wire with connectors and 5 (or is it 6) single leads. What I have been able to figure out is the APM will power the receiver from a spare channel to the "BAT" channel on the RX-702 but I can't find anything out which was up/down and I am assuming if I plug it in the wrong way something will die.
Then I need to wire in the actual data lines. Again Google let me down. As far as I can tell a single lead will be enough as the others are just duplicated power lines. However I cannot find anywhere that tells me which of the 3 pins on each channel (both RX and APM) is the data line and therefor the one that needs connecting.
If someone could let me know, point me at some decent sites etc.
Thanks
Everso
Thanks
Everso
