jamesnater
I have an Eachine Wizard x220 ARF kit and plugged the r6DS to the UART3 spot on the fc.
I have the plug inserted into port 2 of the receiver (S.BUS output? Or so it says...), and cleared a new aircraft in the AT9 transmitter for it to bind to.
Betaflight 3.0.1 has been flashed on the fc, as well as the BLHeli_S ESCs. (I know there's 3.1 now but betaflight keeps timing out when flashing)
In Betaflight, Serial_RX is selected under UART3 in the port settings.
Serial/S.BUS is selected for the receiver in the other tab.
Every time I try to bind them, it seems to bind, but there's no control from the transmitter. I can't arm it, I can't do anything. It's like it won't communicate.
I've held the bind button, powered up the quad, red light flashes, then I turn on the transmitter... binds but not communication.
I switched the light to purple (S.BUS), shut it off and repeated the previous steps, same result.
I also switched the plug from port 2 to port 1 on the r6ds (PPM), and repeated the previous steps, same result.
What's going on?!
Also, I've swapped the rx to fc cable with another and repeated all the same steps and still get this result.
What's going on?!
