Hi mate its best to used matched props as some can be a lot heavier than others, so all the same make will keep props in a weight range ( they must be balanced before use) if your asking about the trim buttons on the transmitter , then if the transmitter is digital programable then it should remember trim setting , but normally if the KK is set up right with the right firmware it will not need to be trimmed
