Stevoillion
Hi,
New to this forum... just saying.
I purchased from Hobbytown the Ares Ethos FPV quad.
It was running well and no to little problems... until now.
I've had a few relatively minor crashes but nothing I would consider major.
So, my problem is that I no longer can achieve lift.
When I brought it back to the store, they suggested that I may have stripped a rotor (so I replaced them, to no avail.)
Next I was told may be a bad mother board (so I replaced it, to no avail.)
Next it was suggested one of the motors may be bad (so I replaced it, to no avail.)
At this point, the store called the help line and they are stumped. If it's not the board (which the store tried two more that they had in stock) and they also replaced the weaker motor - arm a couple of times, and we've replaced the battery as well as checked it to make sure it's working properly... and even pulled out a new radio controller to see if that might be the problem... everyone is stumped.
Does anyone have input or insight?
I'm thinking my next step might be to replace all of the motors in case one is for some reason pulling more current thus not allowing the others to work properly.
Any help is appreciated.
