hondafireblade
Hello
I have a problem with my drone (which I am building).
Practically when I arm the engines the number of laps, set by me on cleanflight, is 1060. When I move the throttle lever (transmitter futaba t8fg) the number of revolutions rises dramatically at over 1600 rpm (on engine 3, the other engines do not change the number of revolutions) then settles there. If I move it again the revs increase and if I bring the throttle stick to the max the laps not only arrive at 2000 but the engines start to make a bad noise.
Can you help me solve this problem?
On cleanflight in the receiver tab if I move the transmitter sticks they move correctly.
This is teh procedure that I followed to calibrate the ESCs:
1) put the drone in leveled plane
2) calibrated the accelerometer
3) calibrated the ESCs, bringing the general lever (on cleanflight) of the motors to the max and connecting the battery. After the various beeps lowered to 0 the lever (other beeps) and then disconnected the battery.
I set the maximum throttle at 1850, the minimum at 1060 and the minimum command at 1000
Transmitter: Futaba T8FG
PDB: Maitek Mini power hub 5v & 12v
FC: SP Racing F3 deluxe (last firmware)
ESC: BLHeliS oneshot42 (last firmware)
Receiver: Futaba R617FS
Battery: Turnigy nano-tech 1800mah 3S 56-130C
Ch1: Aileron
Ch2: Elevetor
Ch3: Throttle
Ch4: Rudder
Aux1: arm engine
Aux2: flight mode (angle, horizon, air)
Aux3: empty now
Thank you all
Ch1: Aileron
Ch2: Elevetor
Ch3: Throttle
Ch4: Rudder
Aux1: arm engine
Aux3: empty now
Thank you all
