Curmudgeon
Good Morning All! For some reason my new FC and RX aren't playing together nicely. I'm running iNav 2.2.1 and everything seems to be working except the receiver page shows all channels @ 1500. The newer version of this FC is supposed to have an internal SBUS inverter and I've tried both the inverted (direct from the RX pin) and the un-inverted signal (direct from the "B" pad on the RX board per Oscar Laing) and still the receiver page shows straight 1500 on all channels. Supposedly on the newer Omnibus F4 Pro boards UART1 is assigned to the GPS and UART6 is assigned to the RX (I believe iNav recognizes correct ports?) and if I reverse the UART assignments I loose the GPS so I'm pretty sure the UART assignments are correct. Yes, I have set the receiver type correctly to SBUS on the configuration page. I'm fairly confident the RX is connected correctly and recognized by the FC because if disconnect the receiver it shows "no receiver" on the configuration page. I have also tried another receiver (XR4-SB) with the same results. I've worn a hole in the internet searching for a fix over the last 24hrs. Any help for this "Nube" would be greatly appreciated.... JW
