Hugh Hemington
After all the configuration in APM, fixing MODE 1 vs 2, then fixing having reversed the throttle (because Turnigy's UI is a bucket of suck), I finally got the props on today.
First a word about Turnigy motors. I have four D2836/8 motors (1100kv). They have grub nuts, two of which slid right down on the shafts and two which didn't -- sliding down leaving about twice the motor shoulder/prop mount gap. So Turnigy is using or contracting "conical drill bits" (worn out drill bits). Also, don't I ideally want two of the prop hubs to screw down counter-clockwise? These are all the same. Later on that.
I screwed the quad to a stand I made from a champagne box so it wouldn't fly away in testing -- it tried to anyway. After weighting the box down with my SCUBA weight belt, I tried again and found that the pitch is reversed. Push stick away causes quad to pitch back and I'm not in "simple mode" having walked around it.
The second issue is that my parts selection is proving to be sub-optimal. I'm running a 4S LiPo on 45amp ESCs into these 1100kv motors, and at the end of a brief test, the motors were too hot to touch. I'm thinking that's not a good sign. Here's the motor on HobbyKing http://www.hobbyking.com/hobbyking/...r_Motor_USA_Warehouse_.html?strSearch=D2836/8
A guy suggested I use a 3S battery but I'd already bought two 4s batteries, and as usual, the HobbyKing info was about as clear as tar. I have a hard time believing my ESCs are wrong. How do you over-buy an ESC? And I want to keep the 4s batteries in the mix, so I think I'll look for different motors (and wait another two weeks).
What I can't figure out is, wouldn't HIGHER voltage produce REDUCED current draw for the same power and generate LESS heat?
If anyone wishes to chime in with a motor suggestion that will turn 11" props off a 4s battery through 45amp ESCs I'm all ears. Oh, and of course, I need to address this pitch reversal issue too. And anything on the merits of counter-rotating prop hubs would be of great interest. Thanks!
