Hello everyone,
I have been flying really hard the past couple of days as the Michigan snows have cleared out. Recently, I was flying over a parking lot doing flips and such until a propeller exploded in mid air, causing the quad to take a tumble. It landed right on the battery and arm. Arm is replaced, but now the battery is in bad shape (Lumenier 1800mAh 4s 75C). It was in rough shape before (in terms of scratches, not puffing) but now a volt meter reads 12v on a 4s. Only 3 out of the 4 cells read voltage. I doubt the 4th cell has actually discharged to 0, as there is no puffing, so I assume it is a bad cable somewhere in the lipo. If anyone knows a fix to this (hopefully without turning it into a 3s, I'm all ears).
Bracing for the worst, however, I am looking into a new battery. I have heard lots of brands other than Lumenier, such as tattu, nanotech, zippy, etc.
I am on a bit of a budget, and was looking at the nanotechs here but have heard some bad things about them, that they are cheaply made, wires fragile, heat up quickly, drop off voltage, and overall just don't last very long. Do these claims have any merit? If so, can anyone suggest another good brand on a budget? Or should I just get another Lumenier?
Thanks in advance,
1251452
PS: is 1800mah the way to go? I would like the flight time, but also know that 1300 would be less sluggish. I do racing and freestyle, but am not hardcore and like the extra flight time
Thanks in advance,
1251452
