BudManLXXIX
Guys I really need your help. I just want a drone like the bug 3. I'm not into FPV, it makes me dizzy and I'm not into areal photography. All the information I can find on building DIY drones seems to focus on these two categories. I just like flying around at moderately descent speeds, above the tree lines and possibly doing the occasional flip with the flip button. I just want a safety net where if the unforeseen happens I can flick a switch and activate the GPS to return to home and keep from losing it. I used to do it all the time on my Hubsan X4. It just wasn't fast enough for my tastes. Last time I asked for help with this they had me building a monster that probably could keep up with a jet. And it was stating to add up to over $700. There are just so my options for autopilots flight controllers out the and It's all so confusing. I definitely want at least a 7'' prop build. I like the stability of a larger drone. I even thought about if I could find the right flight controller maybe I could even retrofit it inside a bug 3 and use a 3S battery to offset the added weight, to achieve my goal. Because the carbon fiber frames are so heavy, which makes it where you have to get bigger motors, batteries, ESC's and so on to get the same performance. which is why people usually go for smaller builds. You see where I'm going with this. I fit in this weird category in between a FPV racing/freestyle pilot and a long range photography pilot. I don't even want a camera on my drone, I intent to not let it out of my sight. But that is not working out to well for me. My problem is not crashing just losing it into the wind.
Anyways I'm asking for your help on suggestions. on what parts to get for a bug 3 replica that just has a GPS flight controller just for emergency purposes. I don't need nothing to fancy . Just telemetry data and a RTH function. Don't need any of that follow me and orbit me modes. No FPV or cameras. I just want it to have a little power under the hood, but not a freaking rocket. I will mainly be flying only in horizon mode. But as I get more familiar with fling a DIY drone I may switch to angle mode for small tricks. Because I don't think any DIY FC have a flip option like the bug 3 has with a single tap of a button. I already have a FlySky FS-16 with an extra receiver. So basic I just need to know what a good choice on a cheap but reliable Flight controller with autopilot and GPS module and I guess a telemetry doohickey. Like I said I'm a bit confused on how all this fits together. I do have a few things given to me by my dad that gave up drone piloting that may be useful to me like a PDB-XT60 and a FS-AVT01, which I'm told has something to do with sending telemetry data. I also have 4 working ESC's from an old bug 3 that I could possibly be reuse. I've already spent so much on replacing lost drones that I'm kinda strapped for cash. So I'm trying to keep the cost down to a bear minimal.
But I figure I shouldn't be that hard to build a DIY drone with around the same level of performance as a bug 3 but with GPS RTH added as a safety net. Like I said earlier it would be nice if I could find a PDB, auto pilot Flight controller combo that is small enough to fit inside the bug 3 body, cuz I do like the look of it. And yes I saw the YouTube video where the guy put a bug 2 flight controller into a bug 3 , which I considered doing until I realized the bug 2 it extremely slow compared to the bug 3. Flying my drone around is almost a therapeutic hobby ordered my my doctor to help with my anxiety. But at this rate it's going to make me homeless if I can't solve my run away drone problem. Any suggestion would greatly be appreciated. And thank you for taking the time to read all my ramblings.
I've been working on this quad for over 3 months now. I like to try to figure thing out on my own first , but I,m at my wits end here. I had one successful flight when I first got it all together then after a small crash because I forgot to take it out of Acro mode and it immediately flipped and crashed after take off. I really can't see how anyone can fly these thing in acro mode. That take some amazing skill. My hats off to those of you that can. After this small crash witch was literally no more than 2 feet off the ground it would fly no more and the remote was making weird noises. After going over it I found out the flight controller was not getting any poer from the 5v power supply off the PDB. So naturally I assumed the PDB was some how damaged and purchased an exact replacement. After re soldering everything with the new PDB I took it outside to test it and making sure to put it in horizon mode this time I started to hover for a bit and then tried to give it a little throttle strait up and it immediately started flipping out of control and crashed. Here is a video of it doing the flipping thing.
Quad Flipping during Punch test
And then started to do what happened after that last crash and wouldn't fly again. I then figured out this was some sort of safe mode, with I still haven't found any reference on. I did figure out how to trick it out of the safe mode by hooking up a 2s batt and switching back and forth between the 2s and 3s a few time and it would fully power up again. Witch why I temporally wired in a 2s batt connector to it until I can figure out how to fix my problem.
But it would still only allow me to hover, the moment I added a little throttle it would start flipping out of control. I figured I may have messed something up in one of the setting In betaflight when I was trying to figure out how to assign new buttons to switch between modes and different features. So I thought I would start from scratch and try again from the beginning. So I cleared every thing to default settings and just encase re-flashed the firmware and did a full chip erase. Everything went successful or so it said. And I reset up the setting in betaflight to the most basic settings. Here is a video of those setting for you viewing pleasure.
Basic setting for Ibus in betaflight. No switches set yet
But now I ran into a new problem. I noticed it wasn't getting any input from my remote so I looked at my receiver and saw it was not powered on. I tried putting power to it manually and still it would not power on. So some how I fried it or it just broke, who knows. luckily I had an extra one. After binding it and hooking it up to the FC I tried once more to see if I could receive input from my transmitter. when I powered on the quad with the batt all hell broke loose. transmitter started making a buch of noises I never heard before as well as the FC. At this put I told my self I need help. Here is a video of me showing you what its doing with also a little more in depth explanation of what I've done so far. I apologize for all my "huhs", I'm not a very good speaker
Drone freaking out
I Thank you you any help you can provide me. Also if I've left out any info that you may need please let me know. Good day and good flying.
Drone freaking out
