davidhk129
I have at least 2 issues :
1. The printing does not start at the center of the bed, It always starts closer to the right side and a little towards the back.
See screenshot...…. printing Elmer Fudd
I know how to use the slicer to center the model at the middle of the build grid before "preparing" it to gcode file.
But that does not deter printing to begin close to the right side.
I did check the X and Y axis. The setting is 0 (zero) for both
NOTICE : the body section is moved slightly to the right of the screen. It shows after removing the supports.
2. I am unable to print those star wars space ships. After a few minutes of printing, the supports will start tilting to the right and I have to abort the printing. I used the same stl file and prepped for gcodes using both Cura. Cura 3.4.1 and Cura 4.3.
Makes no difference. Same issue...…… supports started slanting to the right and the model became distorted in shape.
See screenshot ……. printing X-wing fighter
I'll try to print the A-wing and see what will happen.
