The single white is off putting
or is it the one with the X.
LOL. Maybe the markings are some sort of Chinese morse code. Well seeing as the connectors are keyed (there is a 3rd sub output too) I'll just pick by position and use the 'X' and 'white' as ground to the speakers. I should end up with relative phase (which is fine), as opposed to absolute.
Assuming it has an on off switch, could you not do a continuity test on the switch. Ground should give constant ping as its open through.
Worth a shot. Just tried that, basically hoping to at least find a common ground.
Oh well thanks for the suggestions. This is it BTW.
The reviews on it are all quite positive. It will be replacing this assembly from a ~25 year old Altec Lansing 2.1 computer speaker system.
So I'll be going from a ~3 lb assembly to a 102 gram (22 gram + 80 gram old DLink PS) one.
