Does it fly?i did the motors in the correct way except the fact that i may have put them exactly backwards.
I have the QAV LHI 250, it looks like i did the motors in the correct way except the fact that i may have put them exactly backwards. Can i simply reverse the polarity of all the motors and be fine? or would it be better to simply redo it all?
Never ever reverse the polarity of the motors. They at are made to rotate in one direction and if you reverse the polarity you will screw up the brushes in the motor.
You could have loaded a custom motor configuration and reversed the throttle authority for each if you did decide to reverse the direction of the motors, however I'd suggest against this because The current configuration is standard, even though the other would have flown just fine; it would have been a pain down the road.Its fixed
This is one of those grey areas where "could" and "should" differ. This is one of the reasons I like having all CCW motors with normal right-hand thread. As long as you use nylocks and tighten them a reasonable ammount they don't come off. They are a lot cheaper to replace and then you don't have to worry about remembering which way to turn, or which nut went where.... Yeah, I mentioned that too, but it's probably best to just do it right
