45 amps, but you don't usually draw max, and bout all batteries have a burst rating.I use 1300mah and 15oomah batteries to keep weight down if it helps also make sure the C rating of the packs is up to it. Maximum draw for your setup would be 48amps without overhead so a 30c at 1500mah or above would be needed.
