a. what are you trying to build?
Camera ship? racer? Both of which do not lend well to DJI anything. DJI equipment is very proprietary. Even the little things you do not expect like the coating they put on their motor wires that make them very difficult to solder. You have to scrape the coating off to get solder to stick. If you are building a custom quad, you want to get away from anything DJI. They make great drones, but they spent a lot of time and money to make sure their parts only work with their intended quads. Kind of like apple. It is why i have andriod. That solves your battery problem.
Motors.
Again what is their intended purpose? They should be the last thing you decide on. The first is the type of ship you want to end up with. Then the frame. Then the power, ie, 3s-4s-6s. Notice i left out 2s? Why would you bother? Then the flight controller. THEN the motors. After that, the esc's. Camera equipment should be last and again very dependent on the frame. We discussed the coating on the wires for the DJI motors. The selection of motors when you get away from DJI is HUGE and significantly cheaper, easier to solder and many will blow the DJI motors away if you are looking for a racer. Camera ship? Just cheaper. There, lift capacity and efficiency are more important.
Most motors will run on lower voltage. They are, after all, just winding's and magnets. They will just run slower and with less thrust.
