Hi Joseph , it really depends on the frame and what props your using , On the flame wheel type frame the motor mounts up side down and the prop mount then bolts to the outer case of the motor ,some mount under the arms and the shaft has a clamp type mount to fit the props , can you give me links or photos of the frame , motor, props and prop mounts so I can help you more
