There's a list of problems I've had so I'm including most of them in case they're significant. The parts I'm using are a F3 evo flight computer, a Matek systems PDB, and originally a Racerstar 20A 4 in 1 ESC, but currently I'm using a Lumenier 30A 4 in 1 ESC, a Flysky fs-16x transmitter, and a fs-ia6b receiver.
The build started out fine, but I couldn't get the motors to spin up once I was done. So I downloaded cleanflight, and was able to test all the motors from cleanflight and they worked fine. After some searching on the internet I found that I didn't have an arming switch, added one, and then the transmitter was able to control them. However, during this motor #4 stopped working. I also had briefly changed the ESC protocol in cleanflight between oneshot42, dshot 150, and dshot 300 while troubleshooting, not really knowing what they did. Upon finding that the motor didn't work, I looked up what they were and found that oneshot wasn't supported, so I assumed I had broken the section of the ESC that corresponded to motor #4. I also switched motors #3 and #4 to make sure it wasn't the motor, and it wasn't.
Therefore, I bought a new ESC (the Lumenier ESC), installed it on the quadcopter, and the problem persisted. Through a bunch of trial and error, I found out that no signal (as far as I can tell) is coming from pin#4 on the flight controller (all new connections from the ESC to the flight controller due to the swap as well). Not knowing what to do next, I noticed that the flight controller also had pins 5-8, and that cleanflight had an optocopter configuration that matched the quadcopter with the exclusion of motors #1-4 on the octocopter. So I changed the configuration on cleanflight, rewired the signal wires to the flight controller on pins 5-8 in accordance with the new octocopter diagram, assuming that it would still generate signals for #1-4 but they wouldn't be connected to anything, and since the remaining motors were all evenly spaced it would still fly fine. I was wrong, this made all of the motors stop functioning.While looking this up, I found a video about remapping the pin output for a motor. I attempted to make the signal for motor #4 come from pin #5, and then changed the location of that signal wire accordingly. This did allow for all 4 motors to spin up while testing using cleanflight, but the transmitter isn't controlling anything (although it still connects). There was also a note from cleanflight that the pin was assigned to a serial receiver. I'm also using PPM (I've heard i-BUS is better but I don't know how to do that, and at this point I think I've messed around enough). I've included the CLI code below. Following this, I reverted all of the outputs to their original pin locations, and the transmitter still doesn't control anything like it did before (even when it was just the 3 motors). And at this point I have no clue what to do. Any help would be appreciated. Thanks in advance.
CLI
# resource
resource BEEPER 1 C15
resource MOTOR 1 A00
resource MOTOR 2 A01
resource MOTOR 3 A02
resource MOTOR 4 A03
resource MOTOR 5 A06
resource MOTOR 6 A07
resource MOTOR 7 B00
resource MOTOR 8 B01
resource PPM 1 A15
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A14
resource SERIAL_TX 3 B10
resource SERIAL_TX 11 A07
resource SERIAL_TX 12 B01
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A15
resource SERIAL_RX 3 B11
resource SERIAL_RX 11 A06
resource SERIAL_RX 12 B00
resource I2C_SCL 1 B06
resource I2C_SDA 1 B07
resource LED 1 B08
resource TRANSPONDER 1 A08
resource SPI_SCK 1 B03
resource SPI_SCK 2 B13
resource SPI_MISO 1 B04
resource SPI_MISO 2 B14
resource SPI_MOSI 1 B05
resource SPI_MOSI 2 B15
resource ESCSERIAL 1 A15
resource ADC_BATT 1 A04
resource ADC_RSSI 1 B02
resource ADC_CURR 1 A05
# resource motor 5 none
Freed
# resource motor 4 A06
NOTE: A06 already assigned to SERIAL_RX 11.
A06 set
CLI
# resource
resource PPM 1 A15
resource LED 1 B08
Freed
A06 set
