good info!
@Jackson ill be getting that one then. I have a all the tools I just need to take an electrics class at some college hah I will be doing that very soon
@GJH105775 Ive been reading for days on the electrical stuff of quads, preparing for when I get the rest of the parts, and I am still confused on a few things. mainly what you just said, where I need to have neutral wires. for LEDs ive read that the positive wire is all you need, but then in a diagram ive seen it shows the negative wire connected to the battery(in my case the standoff will be in between). but since I am using a PDB I guess the standoff will instead be in between the PDB and the LEDs. but I am also using a turnigy receiver switch, which adds to the confusion a bit although I am not scared away by it. so pretty much this is what I had in mind for the connections:
4s Battery -> PDB -> Standoff -> -/+ Led wires Leds
for the above diagram, how would the 3x neutral wires fit in. that diagram was without the turnigy receiver switch
This one is with the Turnigy receiver switch:
4s Batt -> PDB -> UBEC(esc) -> T receiver switch positive wire only -> T receiver switch -> Standoff -> LEDs
then I connect the black LED wire straight to the ubec? how do the 3x neutral wires fit in? now that I am thinking about it. I probably don't even need to use the ubec. the PDB JST is the only thing rigjt? im thinking on this too much.
I understand that what I wrote may be extremely confusing but I it makes sense and there is an easier way to do it then let me know. lol I need to know how wrong I am
thanks for the help guys
