Try this.
That didnt work.
All it did was start motor #2 and #4 first, then #1 started and then #3 started.
Basically just changed the pattern of which ones start first
Try this.
Try this.
Ive done the calibrating about 4 timesSometimes when you calibrate none of the ESCs will start at all, if you run into that just do it again, or do them one at a time if pass-through mode is not working well.
Does it work now, or just not work at all?Ive done the calibrating about 4 times
HI mate as for transmitter it will work but the range may not be as good as 2.4g and interference may be a hit and miss when flying , if the setting does not work I told you to change it only goes from zero to 20 , and you think it an esc calibration problem , just plug one esc at a time in to motor 1 pins calibrate it then plug in the next till all 4 are done then remove the red wire from 3 then the one that still has the red is motor one
THat is probably what he is getting at as motor 1 is the only one that needs the red (5v+).So I am suppose to remove the red wire from the other 3 motors? except for motor 1?
In his first post he linked to these:Hi cant say for sure but there has been strange thing happening with all the esc having a power wire , the kk is powered through ESC on motor 1
