SNSTRLefty
My first hobby grade quad was a QX105 Bat that I had very little success getting it flying. I had to deal with two dead boards and long replacement times which eventually led me to give up on it. I later bought replacement motors to get it back in the air because it was the only quad I had with OSD. I got it back together and took it out for a flight. I found that the cloverleaf had taken more of a beating than I had expected, leading to a drop of the signal as I rounded the garage and a hard collision into the wall was the result.
I took it apart and removed the antenna from the camera and tossed everything in the junk pile until I got a new antenna. I eventually decided to put the board into the frame of my first quad, a Cheerson CX-30w for a time.
Then yesterday, I managed to ruin a camera from another quad (gorilla glue fumes are murder on electronics I learned) so I cut the antenna and tried my hand at soldering it on the Bat's camera...
IT LIVES!
So I took it out for a test run with stock pids and the race rates I use on other quads. The camera performs better than the stock ones on the SPC Makers 90X/
IT LIVES!
