So after watching some videos online I'm very interested in building a heavy lifting quadcopter.
Does anyone know where to look at for electronics? Such as the motors and ESC's?
I'm wanting to build one that can lift a couple hundred pounds. May sound kinda odd since I've only been messing around with quadcopters for a few months now. But either go big or go home! Once my mind is set on something I go for it.
Thinking of building an Octacopter to complete this. Will be a custom carbon fiber frame that I will build. Might have to end up using aluminium.
So where do you get motors this big?
I found a motor called the Tiger motors.
http://www.quadrocopter.com/Tiger-U7-Motor-420KV_p_1218.html
It says at an octacopter it would put out 24kg of thrust. So in pounds that is about 416lbs of thrust right?
