I would think that shaped wire landing gear would be light , durable, repairable & shock absorbing S
Discussion in 'Frame Design' started by Flippy, Aug 29, 2014.
  1. Flippy
    Flippy Member
    Has anyone tried this?
  2. Hugh Hemington
    Hugh Hemington Well-Known Member
    I can see how four legs, where each leg has two nylon parts with a piece of, say 14ga. spring wire in a 'U' shape in the middle, would remain fairly light, but also absorb the shock of landings.
    One nylon end would be attached to the frame, the u-shaped spring would be oriented horizontally, and the bottom leg portion would be attached to the bottom of the 'U'.
  3. Long Range RC
    Long Range RC Well-Known Member
    I use these that I made from the the tall crab leg gear. I cut them on a band saw and placed them on my chopper. They spring very well on hard landings.
    mozquito1 likes this.
  4. GJH105775
    I also used some pex pipe bent into a C shape for a hex I did. Great shock absorbtion however on harder landing it did bounce and sometimes flip.
  5. yay
    yay Well-Known Member
    disposable earplugs
  6. mozquito1
    WTF
  7. mozquito1
    In the words of Eddie Murphy
    Get the f#! % out of here.
