John Norum
Not sure if this is even in the correct area, I am totally new to this. A few months back i purchased a Hubsan X4 HD107 quad copter. I have had time now finally to practice with it and basically not impressed by it at all. Most probable is the fact i am doing something completely wrong. After going on line and trying to solve the problem i end up with conflicting ways in which to reset the transmitter. It seems that all the calibration attempts have failed. The most annoying problem i have now is the throttle seems to be the wrong way around. Once you pull the right joystick towards you it throttles up but if you let the joystick return to center the motors speed up which should be on a safety point be the other way around, so when the joystick comes back to center the engines stop. I have tried the factory reset in Mode 1 and Mode 2 but nothing seems to sort this. This is the white quad copter with the screen on the transmitter. Any help appreciated thankyou.
