Brushborder
Hi, I'm new on this forum. Hopefully this is the right place for this post..
I am having an issue with my X4. The left side motors are inoperative. I had to do a little soldering to replace a motor with a bent shaft and a replaced a broken shell. I have not soldered in some time so it is possible that I messed up the board. But, before I replace the circuit board I am wondering if there is anything I should try first. The right side motors spin and have a voltage drop of about 3.5. From what I can tell there is no voltage to either left side motor. I have tried calibrating the transmitter to the quad. I have also tried tilting the drone while the throttle is at full. None of the above make any difference. At this point the M2 motor has a broken positive wire from all of this moving around, but regardless there isn't any voltage at the M2 or M4 terminals.
If I do need a circuit board where can I purchase one for a Hubsan X4 H107C HD?
Thanks!
Thanks!
