Home made antennas.
Discussion in 'FPV Systems' started by mozquito1, Aug 12, 2017.
  1. mozquito1
    The antennas I made in about an hour a piece. For less than £4 each.
    The only thing is they have not been tested yet. IMG_20170812_161110934-1024x575.jpg
    Apparently using 10 awg you do not have to have a wave trap. But it does have to be 0.4mm from the plate.
    So this is what I come up with for 0.4mm off the ground plate.
    I will have to test it on all channels & bands to see which is best. Same withe the omni. I have not got a printer so I had to dig on the info to draw a former template for 5.8ghz. If anyone wants the info I'll post it.
    Gyro Doctor and GJH105775 like this.
  2. mozquito1
    If you know what a wavelength is then you will know what a quarter wavelength is & this diagram will make sense. PhotoPictureResizer_170812_231537619-1024x768.jpg
  3. mozquito1
    d= diameter of wire
    L=length of the coil
    S=1/4 wavelength 11.8mm
    D=diameter of former 17.5mm
    a=space between coil & reflector plate
    R=reflector size 40-50mm
    Jackson, Gyro Doctor and GJH105775 like this.
  4. Gyro Doctor
    ... :rolleyes: ... Well done Moz !
    Now just toss those puppies on a spectrum analyzer and check the frequency response.
    Oh, and some polar coordinate graphs of the radiation parameters would be nice too. ;)
    (nyuck nyuck ... oh, I wise guy heh?) :p
    mozquito1 likes this.
  5. mozquito1
    You seen how much they cost. :eek:
  6. Gyro Doctor
    Yep, they ain't cheap, and it's not like there's a whole lot to 'em anyway !
  7. Jackson
    Gyro Doctor and mozquito1 like this.
