Holystone F181 chaser
Discussion in 'General Discussion' started by mxb, Aug 11, 2018.
  1. mxb
    mxb New Member
    hey any one know why my drone isn't flying I've tried recalibrating it, replacing the rotors, charging the batteries everything I can think of, but the rotors will just spin for about a second and then quit or it will fly about 13 feet of the ground then fall so if you have any suggestions please tell me thanks
  2. Jackson
    Well it's always a good idea to use a meter and check the battery's voltage after charging. Should be ~4.2V.
  3. natnatroswell22
    natnatroswell22 Well-Known Member
    Do not immediately replace everything first know what is the main problem first.
  4. mozquito1
    He private messaged me I told him to open a thread, I said also to check battery voltage after charge & the time it dies. Should get at least 5min. & try not to run them right down below 3.6v as this is no good for the cells.
  5. mxb
    mxb New Member
    ok I did everything you guys told me to do and still wont work any other ideas
  6. wafflejock
    wafflejock Well-Known Member
    Is it actually draining the batteries? Have you checked the voltage before and after flying for however long it will take off? Basically would be good to know if there is a short or some component that is sucking the life out of the batteries or if it is just some kind of software issue or other glitch.
  7. mozquito1
    What did you do,checking the voltage wont make it work.
    What was the outcome. & how much was this f105.
  8. natnatroswell22
    He might need a doctor for his drone
  9. mozquito1
    Sounds like he's waiting on a new lipo.
  10. natnatroswell22
    Hey mozquito do you have any other idea there to solve his problem?
  11. mozquito1
    Not for a dud lipo. Only solution is a new one. Maybe if you had a power adapter with different voltage settings
    5v 7v 12v. You could jury rig an adapter to power the quad. You not get far lol but you would know for sure its the battery..
    Its the battery anyway going from the explanation.
  12. natnatroswell22
    So mozquito suggest buying a new one :)
  13. mozquito1
    He not giving much away so yeah new lipo
    natnatroswell22 likes this.
  14. mxb
    mxb New Member
    what is lipo
