High altitude rtf quadcopter
Discussion in 'General Discussion' started by Farqueue, Sep 19, 2015.
  1. Farqueue
    Farqueue New Member
    Hi Guys
    Im in the market for a new quadcopter, i work in australia in a remote desert area that no planes ever fly and i want to do some high altitude aerial photography i want something RTF and under 2000 dollars with 4k cam or under 1500 go pro compatible.
    What are some suggestions on quadcopters in this price range that have excellent range/ battery life and arent altitude restricted.
    I really like the phantom 3 but it can only go to 500m from what i have read.
    Thanks in advance..
  2. sailorsam
    sailorsam Well-Known Member
    I'd suggest one with one-button-return function. very easy to lose one up high.
    I suspect you've done more of this than I so I hope I'm not stating the obvious.
  3. GJH105775
    GJH105775 Avid Linux User, and U.S. Air Force 1C6 Moderator
    Well most quadcopters will do high altitudes, if you just upgrade the transmitter to be longer range. Just get a RTF that is within your budget (I suggest getting a Phantom 1 because of the longer flight times) and get a transmitter like a Turnigy 9XR with a 1000mW 433mHz module you could get pretty long ranges.
    How much range do you need? You could get a lot longer range with a fixed wing if possible.
