itsniklavs
Hey, so i just got the iflight nazgul5 v2 4S BNF quad. Set it up, tried flying it for a few seconds and it just started literally spinning and dipped mid air.
I couldnt understand what had happened so i tried googling it and looking on youtube and everything, i found out that this is called a "death roll" when the motors "desync" i guess(??)
Thank god a friend of mine was filming my first flight - https://files.fm/u/yg6cq966m if you zoom in super close it looks like it starts rolling mid air but i cant seem to understand which side/which motor is to blame. But when i take off the props and power it up at home, the motors seem to work perfectly fine when i increase/decrease the throttle.
Oh and a general question - should the motors\flight controller/VTX get hot when a battery has been plugged in even when its standing still for some time (5-10 min) or e.g. the motors are spinning with no propellers on?
ANY help will be greatly appreciated since im kinda new to this hobby and theres A LOT to learn Smile
p.s. if there are any settings/info i should check/post here please feel free to tell me! Trying to learn as much as i can.
Thanks!
Thanks!
	 . From there can maybe get another vid of that and just thoroughly test each ESC as you did already on the bench but can do it on the ground with props on and just use right stick only so no throttle input and tip the quad left right forward back (not to far to not scrape up you props).  If under load things are okay on the ground should be good for that LOS test flight.
