I love my Phantom clone, the Aerosky X350.  But now I am having problems.
It has the APM board in it with a GPS with a built in compass. I believe it is a 3D style.
I also have on my computer the APM Planner 2.
When I fly it, and use the circle mode on the controller, lately, it starts the circle, and after about 60% of the way around it starts drifting and then landing!
I used the reset using the APM 2 program. I thought that would re-set all the factory settings. It said it did! But still the same thing happens.
Other than the incomplete circle and landing, it seems to fly normally. The return to home works and so does the headless mode. Just the circle mode seems to be bad somehow.
I did re-calibrate using the APM 2 program. The Aerosky does not have a compass calibration procedure. The manual says it has an "automatic compass calibration", presumably when you start it up.
At start up, it will not let you start the motors until it has sufficient satellites.
Does anyone have any ideas where I start? What could make it do only 60% of a circle (30' diameter) and then wander off and land?
My Aerosky always held it's GPS position better than my DJI Phantom.
