help needed with drone.
Discussion in 'Getting Started' started by fouram., Nov 12, 2017.
  1. fouram.
    fouram. New Member
    Hi there. I am new to drones. Have a drone which is broken, one motor will not light up, took it to drone specialist, outcome is he did not recognise brand, so could not repair. WAS given it as present, bought from ideal world on tv. would appear to be Chinese make of pro viper- called viper pro. Has anyone seen/heard of this type? Does anyone know where I could get it looked at in Scotland? I have no idea what to do, have tel. Ideal World but cannot get through.
  2. Gyro Doctor
    Do a "Google Search" under "RDM Creations, Viper Pro Drone" .... Forget the retail outlet Ideal World, RDM is the manufacturer ;)
  3. SLFLY
    SLFLY Well-Known Member
    Do you mean one of the motors wont spin ? or just led light wont work ?
  4. Brown
    Brown Active Member
    Never heard this type. But you could try some secondary market FB groups to see if someone use it.
  5. Gyro Doctor
    There's not much info on anything made by "RDM Creations" to be found (I did see that Ideal World still sells them for 250 GBP)
    but you can still try the usual approach:
    Disassemble the quad enough to access the main board inside then switch the connections for the motors.
    If the previously dead motor works (and a different motor quits) then you know it's either the section of the board
    that drives that motor, or the wiring that feeds the motor, and not the motor itself.
    If it IS the motor you can probably find suitable replacements for cheap (I'd recommend doing all four at the same time
    unless you're sure they're the exactly the same motors). If it's the board then it will take a bit more work to fix, but it's still
    possible to just replace the driver sections (built in ESC) if you're able to do minor electronics work (soldering and desoldering).
    I saw one of these quads on fleabay for about 100 GBP that you just might want to go ahead and get.
    Having TWO of everything is a great backup plan for parts whenever something breaks, fries, or just plain quits. ;)
