billybutcher
Hi All, another curve ball from the guy that wants it to all work perfectly but without buying it all ready done!!! my own worse enemy...
changes I've made recently which seem to be giving me more jello and shake than before. just wanted some thoughts to see if any one else has come across.
tarot 650,
1. Went from 12" props to 1555
2. increase gimbal rail to 50cm (similar to Ringalongs rig)
3. ordered 12mm carbon tubes but using original bungs fro mounts so a much tighter squeeze (would this increase vibrations?)
quad is balanced with a 4s 8000mah at the back and the feiya-tech 3d mini at the front
sorry one last question, how can I remove the cameras setting from showing up on the lcd receiver screen, its blocking the osd info!!!
this is the last one, had a go last night and had put some pretty well balanced 1447 on and increased the gains by 5 points. on giving it some welly it start to have what i can only say as a tank slapper.... and took at leat 5-10 seconds to regain stability, bloody scary!
thanks from a frustrated Englishman! i will also post this in general discussions
tarot 650,
