Greetings,
I own a Mobula6 HD for about 2+ months. I have a set of (4 pieces) Happymodel 250mAh OEM 1S batteries and 6 pieces of Tattu 450mAh 1S batteries. Problem is:
- I begin my flight at full charge and battery voltage drops so quickly under 4Vs (about 30 seconds on 250mAh batteries and about 1 minutes in 450mAh batteries) during the flight.
- I have a very small apartment building so I'm not even flying so hard or fast.
- When this voltage drop happens my drone can hardly lift off from the ground even at full throttle.
- When I land, battery level increases over 4Vs. And I can lift of for a few more seconds but drone drops on ground level immediately.
- When I plug the batteries on the charger I'm seeing that they have 3.8-3.95Vs of charge (after about 1minute flight time on 250mAhs, and 1,5-2 min flight with 450mAhs-about half of this time is with full open throttle and hardly lifting drone)(that should be more than enough for flight, but drone hardly lifts off at full throttle).
Batteries had 30-40 charge cycles. I use happymodel (generic) 6-in-1 charger. And I charge 250mAh batteries at 0.2amps.
All settings on the drone are stock settings, stock body, and stock propellers; and I didn't make the 48kHZ mod. I fly in Horizon mode (air mode and antigravity turned off).
What may be the cause of the problem? Did batteries die?
Or is it something related with drone hardware?
Thanks for your time, I really appreciate your support
