reillyryan
Hey guys Im new here and this is my first time posting, read a lot, but first time posting.. Ill try to be quick and to the point of with my problem and questions.
So I just built a quadcopter:
S500 PCB Frame (all power is soldered to the board)
DJI e310 tuned propulsion system
Xaircraft Minix FC (do not have the OSD connected since Im not doing any video)
Futaba 8JA(set in quadcopter mode, apparently new, had to revers all the stick channels) with Sbus Reciever
So put it all together. did all the programming and calibrating I knew of. Everything seemed to connect.. Was able to get the quad off the ground, in attitude mode, minimal flying in close range, no problems, then flew further out and higher, then the quad just fell out the sky, as it was falling I could here motor trying to do something, but wasn't able to recover.. Got the quad back together, did a lot of testing this time. What I am finding now is that.. while in manual mode holding the quad in my hand the motors spinn up and spinn down correctly, seems to be all good, did notice that yaw in one direction is almost not there at all.. but have not flown it in manual mode.. Did the same test in attitude mode the motors are very iffy in response, when I arm them they spinn up to where ever the throttle is, but then start to slow down to were only one motor is spinning, when I try to throttle up at that point again the motors are very unresponsive and will almost do nothing.. This was me holding the quad and just sitting on the ground, giving enough throttle to spinn up but not take off.. now in attitude mode I can get it off the ground hover at various altitudes, but after giving input on the sticks the quad becomes unstable in a manner of speaking, it will sometimes drop altitude very quickly for a brief moment, which it can recover from, then some times with the throttle above or at 50% will slowly loose altitude till it hits the ground.. At a level hover.. Giving positive throttle at this point either spinns the motors up to gain altitude or it does little to nothing.. This is also something I have noticed that at various time giving stick input there is a brief hesitation or lose of input to the quad, its very odd to me.. It will fly very level and stable sometimes , it almost seems that as long as I'm giving constant stick inputs if fine, but when I try to level off or slow down is when the problems happen.. Again all this seems to be in attitude mode, haven't done gps mode fearing that if it cant handle attitude mode then gps wont be any better.. I have tried all the calibrations:
esc calibration and esc firmware upgrade
neutral point calibration
reverse calibration
compass calibration
Just really lost and need some help.. Hope what I wrote is understanble and clear, if not let me know
reverse calibration
compass calibration
