ben garcia
This is my first build and well from the title you can see I am having problems. I put the quadcopter together with no problems but when I went for a test flight it wouldn't take off at around 50%. Eventually I put the throttle to around 90% and it flipped over. I googled around to see how to fix the problem and the main thing was to make sure the props and motors were in the right discretion. I fixed this, but when I went to fly it the same thing happened. I did some more researched and then reset my kk2.1.5 and re calibrated the throttle. I went for the third test flight and this time it wouldn't even get off the ground. I had to set the throttle trim all the way up and push the throttle 100%, and then it flipped again. I'm not really sure how to fix this. Here is my part list:
- kk 2.1.5
- afro 20a esc
- Turnigy Multistar 2216-800Kv 14Pole Multi-Rotor Outrunner V2
- S500 Glass Fiber Quadcopter Frame 480mm - Integrated PCB Versio
- 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Red)
- Hobby King Quadcopter Power Distribution Board
- ZIPPY Flightmax 2200mAh 3S1P 40C
- Hobby king 6ch transmiter
