DForesi
Good evening Ladies and Gents,
My name is Dan Foresi and I'm an engineering student from Canada. A few months back I started looking into building my first multirotor and got quickly entranced by all the various builds on various forums. The goal of my build was to design and construct as much as I could on my own and come out with something well suited for flying.
I ended up going with the following general layout:
- X configuration quad
- 12" propellers
- Dual 5200mAh 4s batteries
- 700Kv sunnysky motors
- Naze32 flight controller
- Turnigy 9x radio and receiver combo
- Carbon Tube arms with Tarot motor mounts
So far I've made some good progress and I'm happy with how the build of the frame and everything came out. Unfortunately when I went to do my first test flight I had a pretty violent crash and I'm not sure what happened! I started to a YouTube video series along side the build and managed to catch the crash on video. I'm not here to plug my channel, you can see the exact moment of the crash at 5:50 in the following clip:
As far as I can tell all of the motors were spinning in the correct direction and the CW and CCW props were matched to the right motors. I did notice that even after calibrating my ESCs I could never get the all the motors to activate simultaneously. After tinkering with things for a bit 3 out of the 4 motors stopped working. I have tested each ESC individually and they all still function perfectly when connected directly to the receiver but they do not function when connected to the NAZE32. I have ordered in a new flight controller, also a NAZE32 in hopes that the control board was faulty.
I've reached the limits of my knowledge in this area and I would really appreciate any input you all have to offer.
Thanks for your help!
- 12" propellers
