I agree the Turnigy 9x has an attractive price, but you'll soon become unhappy with the quality and limitations of it. I moved to the Taranis and I wish I'd started there. You can setup/backup your configuration on your computer and download it -- way easier than navigating the menus!
I also agree 1000kv is a little light for a fairly heavy 550 frame (the rule of thumb is 1g/mm motor span) so this one at 598g is over for a 550mm frame. I tried to build a lighter 610 with 1100kv motors, so I've made the mistake(s)!
Not saying it won't fly or even fly well, it's just a spec. concern. I've got 720kv SunnySky motors on my 560 frame @ 520g, but you can't get those at HobbyKing.
I see the "introduction" quotes a 3S lipo, but a 10" props (and 11" props elsewhere in the article). Note the motor specs. quote 8" @ 4s and 10" @ 2s so you need to observe that, or split the difference. (Yup! I made this one too! Tried to fly those motors with 11" on 4S!) 3S is a good size as it supplies power to 12v FPV gear directly, saving you the need of a UBEC unless something needs 5v. You may find the motors get hot running 10" props on a 3S. Think about also getting a set of 9" props or watch your temp and keep it in mind. I know this seems backwards -- "more power should turn a larger prop", but props require torque which is related to current-draw, so voltage oddly works against you.
I find the SimonK firmware on the Afro ESCs makes a lot of difference and I have a set of Afros and a set of MultiStars too. I just got the programming connector to do my MultiStars, but it's around $20 plus $10 for a USB-ASP, so the Afros are actually a pretty sweet deal at a buck more a piece up front. And they're 3.5mm bullet terminated too.
On the whole, the configuration should get you up and flying successfully. Getting a better radio will not alter things, and neither will slightly better ESCs. Before you're done, you'll have two or three of these things, and drawers of parts and tools. There is something oddly addictive about it!
