DaGGerS
Hi all,
recently came into this hobby.
trying to build a quad X with following components:
Frame: Reptile 500 (generic)
ESC: Generic 30 amps
Outrunners: Generic 1400kv
FC: MultiWii SE v2.5
TX-RX: FS-TH9X
Battery: LiPo 3S 5200mah 30C
building steps:
frame assembled = ok
motor mounted = ok
ESC mounted = ok
diy built power distribution board for ESC's and mounting = ok
ESC connected to outrunners and with power distribution board = ok
checked connectivity by connecting battery and bldc tester (servo tester) = ok
FC installed = ok
latest firmware loaded in FC v2.4 in FC = ok
FC configured with MultiWii GUI = ok
calibrated Accelero and Magneto in GUI and write = ok
rx connected with FC = ok
tx configured for acro = ok
battery connected with power distribution board = ok
problem:
one motor No. 10 keeps beeping after FC self calibration
rx indicator light stable but no movement in motors when giving throttle
when connected with MultiWii GUI, it shows that the tx-rx is working but there is no physical movement.
i am unable to arm the quad and tx-rx commands works directly without arming command
when directly connecting the esc with rx it works but when connected to FC they don't work.
checked all ESC's with their programmer for all settings which are ok
any suggestions.
TX-RX: FS-TH9X
building steps:
motor mounted = ok
ESC mounted = ok
FC installed = ok
problem:
any suggestions.
