K koklimabc Active Member Mar 22, 2021 #1 As per topic, I suspect my prop setup could have wrong directional setup I'm using prop out (reversed directional). It just spin out vertically 360 degree and drop into ground. Then my telemetry lost to my controller. why? Attachments IMG_20210322_135704.jpg 802.7 KB · Views: 3
holtneil Well-Known Member Moderator Mar 22, 2021 #2 Hi it's hard to see in the photos but a standard set up is Front left CW Front right CCW Rear left CCW Rear right CW
K koklimabc Active Member Mar 22, 2021 #3 holtneil said: Hi it's hard to see in the photos but a standard set up is Front left CW Front right CCW Rear left CCW Rear right CW Click to expand... problem fix, I'd everything good to go. BTW, TQ for your reply.
holtneil Well-Known Member Moderator Mar 24, 2021 #4 So what was the fix , it help others if you can say what was wrong
K koklimabc Active Member Mar 24, 2021 #5 holtneil said: So what was the fix , it help others if you can say what was wrong Click to expand... That is easy, I'd just change "Yaw degree" to 90 (can be 180, 270) degree for FC alignment (Configuration tab of betaflight), since my VBAT + & - (Battery Terminal) shifted to left side, I'd also manage to change resource motor to correct direction (CLI command : set resource motor 1 XX), "prop out style (reverse)" requires my prop to have lead out (most thickness edge must face out side).
holtneil Well-Known Member Moderator Mar 25, 2021 #6 Brilliant mate glad it sorted and info helps others
