Creating a drone launch pad
Discussion in 'New Products' started by Shado_, Oct 12, 2016.
  1. Shado_
    Shado_ New Member
    I am currently doing A-level 3D product design and I am in the process of creating a drone launch pad. The product will reduce the likelihood of the drone coming into contact with mud, water etc.; enable the user to quickly measure 50 metres from the product (to check if complying to CAA regulations) and provide a flat and level surface for the drone to be launched from. I would greatly appreciate it if you would answer the short questionnaire posted below so that I can make my product to a standard that suits that majority of people. Thank you in advance.
    https://goo.gl/forms/T2jP4TYG1Y7R9pbi2
  2. GlassKnees
    GlassKnees Well-Known Member
    For my purposes, I'm more interested in the following:
    • A clearly marked launch pad area so potential bystanders know to keep away from it.
    • A surface that prevents dust/debris from flying about damaging the aircraft/motors
    • A means of leveling on a surface that is uneven
  3. RENOV8R
    And duel purpose so I can use it as a splashpad Bwahaha
  4. scottdavey
    scottdavey Member
