HI mate look at the kk board the pins on the left are for the receiver in put , the pins on the right are for the motors , so why have you no escs plugged in ? the kk board takes the power from esc plugged in to m1 (motor one ) so remove wires from board plug the receiver thro, elev, etc as in kk2.0 manual if you have not got this go to hobby king find kk2.0 and look in file section, it is very inportant to get wires right way round, now plug esc wires from motors 1 to 4 in to pins m1/m2/m3/m4 they are the pins on the right, ok now load motor layout , after this turn on transmitter put throttle to full, now hold down buttons 1 and 4 while held down plug in battery your hear some bleeps then lower throttle it will bleep again now let buttons go , un plug battery , plug battery back in the board will show safe, go into menu look for receiver test and make sure all is right throttle reads idle so test each control if all working right then great if any need to be reversed do so .now go back to safe hold rudder to right it then read armed push throttle and motors will spin , make sure they go right way round , if 3 spin and one is slow to start , if you go into menu and adjust throttle up from 10 to about 20 and test again all motors should start same time ,
