BFlight 210 and Taranis QX7 not working
Discussion in 'Newb Guides' started by Drone Guy, Dec 29, 2017.
  1. Drone Guy
    Drone Guy Member
    I got a Bfight 210 with a BNF FrSKY receiver and a Taranis QX7 Transmitter for Christmas, and managed to bind the drone and transmitter, but the propellers wont spin. I have spent a few hours on the web, and found nothing. Also, betaflight shows the throttle idle, and the bars won't move. I am a total newbie with drones. Does anyone know a way to get this to work? Thanks
  2. mozquito1
    How have you got the rx setup pwm, ppm or sbus. Are these wires to the correct pads. Google a pinout diagram for whatever flight control board you have in it.
  3. mozquito1
    I can't find a quad with that name to see what board it is sorry. Just getting a load of different 210 size quads.
  4. Drone Guy
    Drone Guy Member
    I bought it fully built from: g e a r b e s t - c o m / b r u s h l e s s - f p v - r a c e r / p p _ 6 6 0 7 9 4 . h t m l ? w i d = 2 1
    They say it has a "OMNIBUS F3 Pro FC with OSD".
  5. Drone Guy
    Drone Guy Member
    All the reviews say it works out of the box.
  6. mozquito1
    Yes they all do but some of them don't.
    They may have missed a small step.
    Like selecting rx ppm or sbus in the configuration tab in cleanflight.
    If your channels are not mapped it won't arm. Check the Aux channels are setup in modes tab in CF.
  7. Drone Guy
    Drone Guy Member
    Great! I got the receiver connected to the flight controller. The bars in the receiver tab are moving. I followed a video on setting up the arming switch. I went to the modes tab and set up the arming switch range. When the value goes into that range, the name doesn't light up. All of the other modes light up when in the range. I think something is stopping it from arming. Any ideas?
    mozquito1 likes this.
  8. mozquito1
    Min throttle range needs to be below min esc range. my min esc range is 1005
    So min throttle being 1000 is below.
    In rx tab & with the throttle trim on the Tx move it down to 995 or move the min esc range up a bit. If that don't work then I'm stumped.
  9. dragger201
    Just somethings I discovered................
    Make sure all other switches are in the off position before you flip the Arm switch.
    Make sure the throttle is all the way "down".
    Set the quad down on a relatively level surface and give it 5 to 10 seconds before Arming to give the gyro/accel time to stabilize.
    I've gone nutzo over all three of these things at one time or another..........
  10. Drone Guy
    Drone Guy Member
    I just broke the USB port on my drone, so once a new FC gets here, I'll give it a try! Thanks for all your help!
  11. mozquito1
    Don't chuck that board it's still useful.
    Buy a ftdi chip or Arduino nano.
    Solder some pins on a spare uart.
    Job done you got a USB back.
  12. Drone Guy
    Drone Guy Member
    I still have it! I have a habit of keeping spare electronics around. I don't know how to connect a uart, but I'll do some research. Would a uart port allow connection to betaflight? I thought it was for a receiver or things like that. I already ordered a new drone from gearbest, but if I am lucky, I will get the old one to work too.
  13. DrAbsurd
    DrAbsurd Member
    Two things ive notice in betaflight with my Armattan Chamellion with the CL Racing F4S AIO flight controller. It wont connect while the controller is on every time. USB no battery and it connects every time. I found the answer to that in the video bellow. The other thing is no matter what I do I cant make the top left toggle switch do anything else but failsafe.
  14. mozquito1
    Have you tried moving it in modes tab,
    Then assign the Aux switches on the Tx.
    Swa or Swd, the 2 outside switches are best anyway for arming.
  15. chinaevacase
    chinaevacase New Member
    it's very strange,
  16. DrAbsurd
    DrAbsurd Member
    I don't like the outside switches to arm. Those 2 are the easiest to hit because of hand movements, how I hold my controller anyways. The left is my kill switch and the spring loaded one I made an emergency stability mode switch to help get out of crashes quickly.
