Hi mate for the fpv and quad to run off same battery you need 4000mah + most go for 5500mah but check weight and size will fit the quad
Sorry cant remember what quad you have , if you have a 450 + size and cant fit a single battery you may be able to mout 2 batterys one either side and then go 2200 mah which will give you 4400mah
