Hi mate do you mean the KK 2.1.5 , Ok have you balanced the blades , when you set up the KK you can either use stick to switch on self level or aux on the transmitter ,self level will display on the LCD screen , If you can do a video that will be a great help , wobbles due to the KK is normally a gain problem if its a fast wobble its P gain to high a slow wobble is I gain to high ,
What firmware do you have we all re-flash with a none hobby king code as the code is not very good use Steveis1.8s1pro but your need the flash tool to re-flash it
