Carter7868
For my first quad, I decided to build a 450 and go with some cheap Emax xa2212 980kv motors (starting to regret this now ). I have simonK 25A ESC's and an APM 2.6 my props are APC 10 x 4.5. When I first put together my quadcopter I got it all working and then all of a sudden the motor started twitching and quit on me. I later ordered some replacements and I ended up going through 3 motors that only lasted a couple of flights. I know I must be doing something wrong but I cant figure It out. When the motors stop working I checked the resistance on the leads and found out that every time one of the wires is not connected to the other 2. This must mean that the wires are breaking inside of the motor. Are the motors just cheap so the wires vibrate apart or is this some how my fault? I spent lots of time trying to fix the motors but I haven't had any luck since it is nearly impossible to get at the part where the wires are connected since the casing is in the way. I am really hoping that I can solve this issue soon and get on with flying since this is really frustrating. If the problem isn't me and its the motors could I replace them with SunnySky X2212's? They are a little more expensive but they seem to be what I am after. Or should I skip the china motors?
