Advice wanted on how to mount ESC s?
Discussion in 'Build & Tune' started by photojunky, Jul 10, 2018.
  1. photojunky
    photojunky Well-Known Member
    The bottom of the motor mount will not work. The 16 mm tube itself will work with 2 layers of double sided tape and a zip tie, but I am not sure which route to go. Any advice is welcome. 20180710_092854-1.jpg 20180710_092902-1.jpg 20180710_092955-1.jpg 20180710_093005-1.jpg 20180710_093057-1.jpg 20180710_093103-1.jpg
  2. holtneil
    Hi you can do what I did with my 900 quad run long wires from ESC to the motor and mount ESC in the frame then run the wires down the inside of the arms, but don't make the motor wires short just to make it look tidy when you do this as some times the motor wires length is all part of the windings
  3. ringolong
    ringolong Well-Known Member
    On top close to the motor mount will help keep them cool. Those are some solid escs btw.
  4. photojunky
    20180710_184228-1.jpg 20180710_184211-1.jpg I decided to mount them underneath the arms. Nothing fancy.
  5. mozquito1
    They're fine like that. Just be careful you don't knock a cap off tightening a zip tie. They can be brittle.
