I don't see a 3s listed so I'm guessing you did some calc's to come up with that figure. The 4s 465kv with 18x6.1 prop produces 920grams of thrust at 37.5% throttle while drawing only 4.3amps at a lb/hp efficiency ratio of 24.01. The 6s 465kv with 18x6.1 prop at 37.5% throttle produces a whopping 1850grams of thrust while drawing 8.4 amps at a lb/hp efficiency ratio of 16.44. The lifting power increased dramatically at the expense of flight time. I guess what I'm trying to say is that from what griz described he'll have a AUW of about 7000grams without the boat. The 4s battery will give him more than enough power to hover at a little under 50% power with very good flight times for video. When he flies with the boat the heavier 6s batteries will easily handle the additional payload but with a shorter flight time. He won't even have to change props. I was trying to give him a simple solution for changes in payload and types of flying. Make sense?
So far I have only about 425 dollars in the frame. In total im looking at around 3500 dollars , maybe a bit more spread out over about 6 months .Now what about budget how much have you spent and what do you plan to spend?
I would say either, unless you wanted something geared more towards autonomous flight (if that is specifically your plan)KDE 4215 motors with 75 amps ESC and KDE props . The controller is whats giving me a headache . Want a good one but don't want to go back to collage to learn how to program It . The super X sounds good but the naza has a long proven track record . Need a push in the right direction .
The SuperX would also be my choice.The SuperX has autopilot. Griz. Check your inbox.
Haha, Windows 10 updates are having about a 50% success rate at the moment. I upgraded to Linux on my main HDD of personal computer a while back. Have not regretted it one bit xD.Sorry guys about taking so long to git back to you . Tried to upgrade my computer to windows 10 . Big mistake . Just now getting some of the bugs out . Lost most of my favorites list and a few other things . Will get back on here today and let you know whats going on .
That sucks...... I was thinking about doing the same. Now I think I'll just go Apple when they go on sale the first of the year.Sorry guys about taking so long to git back to you . Tried to upgrade my computer to windows 10 . Big mistake . Just now getting some of the bugs out . Lost most of my favorites list and a few other things . Will get back on here today and let you know whats going on .
